Injectors flood the cylinder beyond stoichiometric, or to the point you won't have a clean burn in the cylinder and/or it won't fire at all. What raw fuel that doesn't turn into vapor (and eventually lead to catalytic converter failure) will reach the piston and leaks past the piston rings into the crank case.
yeah.. basically the computer was enriching the fuel to warm the engine (it thought it was still 40 degrees) but it was actually 70 degrees (less dense air) causing basically washing the cylinder walls with unburned fuel because the fuel/air mixture was too rich to burn. The O2 sensors were going trying to correct the over rich condition by adjusting spark advance/timing(or something like that) which caused even more fuel to be unburned and into the cylinders because I was flooring it to get to 1000 rpms and move the truck off the road.. so the ecm said and killed the truck.. allowing the unburned fuel to drain into the pan.. By panic starting it and bouncing the throttle to get her to move I made the problem worse and foaming the oil..
IF Greg's foaming is due to a rich mixture resulting in fuel leaking past the rings I speculate its something that's been happening slowly over sometime, not just from this one single event.
Fuel dilution is a problem found in diesel engines running excessively rich.
If a gasoline engine encounters fuel dilution to the point that the fluid level in the crank case increases it will have the cylinder walls washed clean of lubrication and you need a major overhaul.
And that quantity of gasoline in oil will not evaporate for days (Take a quart of gasoline in an open can and set it outside, how long does it take to disappear)
Also, if you would dump that quantity of fuel in to the combustion chambers you would have backfires of the kind that separates the exhaust from the headers and considering the short time you drove the truck the injectors can not flow that quantity of fuel.
