WorldTour
Greg,
After reading your last post... change your oil.
Greg,
it was a short time, but panicking i was mashing the throttle to keep rpms up enough to move the truck safely off the road. So wide open throttle for good 15 minutes. Several failed attempts to restart. I am sure there was enough fuel to raise level high enough to be whipped up by crank.
As far as disappearing excess fuel... I think the 3 hours sitting(allowing separation) then being started and test driven, then left idling took care of the extra quart or so of fuel.. Which first tech reported slight high but in safe range.. Then it was left idling again, test driven (total of 50 miles) and fluid levels reported as normal.
-Greg
So that is why it sounded like a chevy vega with glass packs running on 3 cylinders...
But since the engine was cold and not warmed up, the piston to block clearances are a lot looser and will allow fluid to pass through. That is why you have piston clatter during a cold start..
-Greg
Must have burned up extra fuel ******* the tow truck... Lol
-Greg
over 99% of the unburned fuel will go out in to the exhaust
