B E N
I ran a full race radiator on my 11 ecoboost, quality was good. Overall the increase in cooling when towing was marginal, bought a little time before I had to back out of it but once heat soak happened I was still slowed down, and it put to much heat in it to get back going full boogie, I probably picked up 5mph on the steep passes.
I would look into opening up your hood vents a little, I believe these trucks have inadequate heat extraction, that will be an inexpensive thing to try and I bet it helps a bunch. Ford kept the vent openings small to keep the engine bay clean would be my best guess, and it is probably adequate at high speeds where there is good draw on them. The raptors come stock with the heavier duty ford radiator so any stock size radiator is going to be mediocre in the upgrade department, to see real gains from a radiator your going to have to modify the truck to accept a larger radiator (thicker, wider or taller, maybe all three?).
