Ok, so even with the open trailer and "just" the Evo on it, I saw 220-225 coolant temps on baker grade and mountain pass going 65-70 this weekend with 90* ambient temps. So the radiator is definitely needed (which we already knew).
Oil temp doesn't seem to effect coolant temp, coolant goes up and stabilizes and oil goes up at its own pace that is slower than coolant. On the longer grades oil temp got up to 242. Not a huge deal, most OEM vehicles run 240-260* oil temps as normal op temp these days. Cruising flats oil surprisingly stays at 170-190ish. Due to that, I'm reluctant to put an oil cooler on until I see how it does with the radiator upgrade. Even with a thermostat for the oil cooler, the cooler still gets about 10-15% oil flow so that oil is circulating through it and the system isn't shocked with thick/cold oil when the thermostat opens. My concern is that with an oil cooler the oil will run cold, especially without a load and/or in colder weather.
The trans doesn't run that hot. It seems to stabilize at 210-215ish, only going up from there when coolant temp is higher than trans temp. So I feel like high coolant temps add heat to the trans. So again, I'm just going to put the radiator in and see how everything does. This may change based on what I see with offroading where the converter is unlocked more often, but we'll see.
For now I'll be doing just the radiator, getting more data, and I'll go from there.
