Raptoyd11
Lots of different ways you can put a iPad mounting solution together with RAM parts. the B-size (1") balls and arms are less expensive and are definitely strong enough, but you do get a bit more vibrationflex/bounce in it, especially if you are on a very bumpy road. The C-size (1.5") just tightens everything up. The iPad cradle works with either size, so you could reuse that part. You could even make your "double ball" with one 1.5" ball and one 1" ball, and use the heavier arm for the longer, bottom piece and a lighter arm for the short upper piece.
Here are the parts to put it together exactly as I currently have it...
Dumb question so forgive me, have not had much experience with vehicle electronics. How are you charging the unit and playing music at the same time? Using the 3.5mm and a cig charger or is there a better way? If using the 3.5mm does it sound okay? I have heard the sound is better off the USB. I am asking because I just bought an IPAD 2 I would like to use in the Raptor.
