MagicMtnDan
Great thread guys - lots of useful information, thanks!
I've been using an iPad in my truck (FX4, not Raptor as you can see...) since I bought it this past Summer. I had a similar solution in my Touareg. Swap the iPad back and forth.
Love it!
Much more functionality than any factory nav, traffic, topo's, internet searching for addresses or businesses, etc.
Done with RAM mounts, C-size 1.5" balls. I've used a few different arm configurations, but I get the maximum flexibility and rock-solid stability wtha medium arm, a short arm, and a double-ball connector.
I mounted it to the center console instead of a seat bolt. Plenty strong for the iPad's weight, and less intrusive.
Perfect positioning for my to see and use when behind the wheel (yes, I pull over if I have to do anything more than a a few taps). No interference or intrusion for the passenger, they can still see and reach without any obstrucion pretty much every center stack control except the passenger heat knob. For that, they just have to look over the ipad. Of course the whole thing just swings into an alternate position with a single adjustment knob, so no big deal if you do want it out of the way.
Power is supplied via a cig. light iPad adapter in the center console, with the wire run under the front center console to the iPad. Audio is streamed from the iPad to the stock stereo via bluetooth. You could also hook it directly up to the USB, but the stock USB port will not charge an iPad.
Google traffic overlay...
My primary GPS app, MotionX Drive. Allows preloading of routes when you will be out of GPS range.
Another GPS app by the same vendor, MotionX GPS. Does not provide turn-by-turn navigation, but does allow you to pre-download extremely detailed road and topo maps.
A little more useful than sync "reading" you the weather forecast?
Heey everyone,
I use the pro clip from brodit but i have no idea if the ship it to the states!
the solutions you guys are running seems nice 2!
List*Ford*F-Series 150*2011*|*Brodit
and then just mount the iPad with an active mount to the pro clip and works like a charm! you can even add a tilt ball between the iPad mount and the pro clip!
While I haven't had a chance to see how it holds up off-road, I created an alternate method of mounting the iPad using the "business card" holder in the dash.
I started with a block of wood that I cut to fit the enclosure (I started with the insert and worked my way from there). Once I was comfortable with the fit, I used Gorilla Glue to attach the RAM mount ball to the wood.
To complete the install, I used felt pads on the sides to give it a firm fit. Nice thing about not drilling any holes, I can easily remove it when not in use.
