Front License Plate Option for the R
BBR
Race City NC
Can you swap out the tow hook for one that works with the tow hook brackets?
Back when I needed a front plate that was the cleanest option.
FullSend
FullSend
Colorado
I hadn't looked into it but I am sure you could. But I wanted to keep the fancy red R hooks and also didn't want to lose the usability of the hook. But that could be another option. I wasn't planning on using those front two bolts on the modular bumper so still seems like a cleaner/cheaper option.
rsbug
N Texas
I scoured the Internets and this forum trying to find a good front License plate option, but surprisingly couldn't find anything for the R. Front plate is required here in CO and didn't want to drill into front bumper. The red square hooks can't accommodate the tow hook options ……..
Any of these work because I just used the mounting plate itself:
Thanks for the info on this, I’ll need an alternative location for the plate as well after the hidden winch install. I reached out to Swarfworks to see if they were going to build one for the R.
Correction………….
[ turns out the Swarfworks will work on the 23R, plus the front bumper is different, so the one on Amazon won’t work anyway, I still have a lot to learn on the differences between the R and regular raptor except the engine ]
Burt
Auburn, CA
I scoured the Internets and this forum trying to find a good front License plate option, but surprisingly couldn't find anything for the R. Front plate is required here in CO and didn't want to drill into front bumper. The red square hooks can't accommodate the tow hook options that the non-R versions can use. I found this cheap molle panel style one on Amazon and used one of the pairs of T40 Bolts on the Front to mount the adaptor plate. Probably not necessary, but I used some nylon washers in between the bumper and plate, and also some thin/small foam backing where I thought the plate might touch the bumper. Thought it worked out really well and wanted to share this for others looking for an option.
does the plate interfere with any of the bumper sensors?
