GEN 2 ICON .5-2.25" Attitude Adjustment Collar
Slow6
AK
Has anyone put these on set at 1"? I was something that still has a little rake. I don't like the idea of the CAS system requiring the shock to be disassembled and not a fan of the design of the RPG adjustable.
I don't like the way the RPG adjustable perch looks either... but I also can't figure out why Icon can't have a nice blue collars to accommodate my OCD. I'm back and forth about which one to get, I like the adjustment options of the Icon and how it's split between spring preload collar and top shim, but I see where there is a gap at the seams of collar even though it's tight on the shock body (again with my OCD). RPG adjustable collar, but the RPG version with that snap ring... either that or get the RPG "static" collar until it's time to replace rear leaf springs and either do geizer springs in front or complete swap of spring and shock assembly to get the ride height/stance.
Ralphy1798
Finished product. I think I actually prefer the ride now vs stick.
f90cfe925bf7f8089cf23f888cea1e92.jpgd378e100e4d271bd1e91c221fd4a0ca1.jpg165cfe662ad7428d24d750387b0c33d3.jpg
I am debating between 1.5 and 1.75”. How do you like 1.75”? Is it perfectly level? How’s ride quality? Do you have any weight in the bed (even a bed cover or anything?)
maximus5403
Florida
My truck on 1.75 is slightly nose high. I'll probably get deavers +3 eventually.
Ralphy1798
Dude! I don’t get it, haha.
Until I read this, I was about to post this — I think I'm going 1.75" - I measure 2.125" difference in the street with just bed cover and bed divider (how I drive around most of the time).
Then I measured 1/8" drop on the rear in the driveway, just from weight transfer of the slope.
Kids (180lb in bed) lower it another 1/2".
So on level ground with 180lbs in bed, 1.75" is perfectly level.
I think 1.50" is too little
Umlify
What’s the consensus, do you need to get an alignment after going up 1.5”? Just ordered mine and it seems 1.5” is perfectly level, just need to know about an alignment. Thanks
Ralphy1798
I did 1.5” and it’s great. I haven’t measured how level it is, but I’m super picky and I’m happy. I got an alignment, yes.
R
Rick@FreedomMotorsports
Guest
They will probably remove the shock to put the top load shim on and moving and adjusting suspension around like that, its always recommended to check the alignment afterwards.
Thank you for the order for the ICON ACC by the way, I appreciate it!
We have 30 of these in stock ready to go on our Pre-Black Friday Sale going on now.
