Heated Wheel Retrofit
brysgarage
MA
Could somebody confirm if the APIM has to be backed up and re-loaded, or if we can simply install the vac + SCM and then make the updates to APIM.
Could someone also confirm if there is no way to get rid of the HVAC module DTC once the new one is swapped in.
Thanks!
brysgarage
MA
Anyone have the attached DTC that wont clear in the HVAC module? Everything seems to be working ok. Its 98 degrees here so my steering wheel is already hot but the button is working so I assume it is.
I have this DTC as well. Has anybody determined how to get rid of it? My 23 raptor. Used HVAC module NL3Z-19980-S
TsunamiR
CLE
Would someone be willing to post the “sequence” and “to Write codes” for what and how to program Forescan once I install the HVAC WITH THE DIGITAL readout?
Thanks
fordfreek
L'Anse, MI
I'm out of touch with alot of this stuff, but that code looks like maybe the dealer needs to program the module? I'm not sure what forscan is capable of doing.
laramie1pt8t
NH
I dont know if there is a way to delete it from everything I read on the F150 forums. I used the same HVAC, non digital read out, but a brand new one from OEMFORDPARTSDIRECT.com. Again everything functions fine, I wish I had a friend who was a ford tech so I dont have to explain the issue to someone at my local dealership.
Stormtrooper
Raptor R
Huntington Beach, CA
I have the full kit still in the box from Boosted Grey Goose if someone is interested?
They are asking $585.98+ tax and still sold out on their website.
Asking $500+ shipping
ToadSmasher2K1
Home Is Where You Make It
Red Kingdom
Is there a way to get climate soft buttons on the side cards without using Unreal? I’m not sure I’m a fan of unreal
