Heated Wheel Retrofit
Donmatteo
Santa Clarita / Coronado
Thank you for this. The only question that I have is about the HVAC control. The part number that you have on your invoice is completely different from the part number that they have listed on the heated steering wheel service bulletin. The one on the bulletin is : NL3Z19980S. It is also $300 cheaper but doesn't look like it contains the displays on the knobs as the one you have listed does. Any reason for the one that you have over the one listed on the service bulletin? Cheers
I had the work done before the bulletin came out and that was the only option at the time. Plus I wanted the temp numbers so it was fine.
