xxaarraa
Here's a new one that adds a "Specified" to the TPMS screen showing what your placard tire pressure is. If you have same pressure set for front and back at BCM 726-40-01 xxxx **** xxxx, 1 value for specified shows. If different pressures for front/back, both values show
IPC 720-04-01 xx*x xxxx xx
If default is 0, use "8"
If default is 4, use "C"
Very nice Liv, thank you. The specified value is not user-inputted correct? It will show whatever is specified by ford?
