2022 801 A Oxford White
slater
Central US
2022 Ford F150 Raptor Special Order;
Auto Start/Stop Delete - Torsen front diff - Heated Steering wheel
55,500 miles (will continue to go up, from daily driving) $72,500.00.
The truck is serviced at Ford every 5,000 miles, tires are rotated/balanced every 5,000 miles at Discount Tire. Only use 93 octane fuel.
Located in Louisville, KY.
I Love this truck and can't believe I am selling it, but replacing it with an F250 for work and I don't need both. This thing is solid, its been to Wyoming twice for Waterfowl hunting trips and is used as a daily driver. Turns heads everywhere and is a joy to drive with the tune. Please DM with any questions.
Upgrades
  1. Eibach level springs – powder coated black. Installed at Ford dealership per Ford specs. Springs, Labor, Powder Coat - $1300.00
  2. Airlift removable airbag kit for rear coil springs. $150.00
  3. Baja S2 Reverse light kit and SPV Wiring harness to engine bay for Aux Switch. $400.00
  4. ADD Bomber Bumper w/lights and ACC bracket. $4300.00 – Only one small lower section of shutters was removed for ACC bracket the rest are in place and functioning properly.
  5. Lomax Bed Cover – 1st GEN, not current model - $1100.00
  6. COBB Factory location intercooler/Drop-in Filter/Radiator Shroud/Intake Scoop bracket – $2350.00 – Stage 2 programmer. The lower shutter system is still functional and was not removed. The box was trimmed to allow for the larger intercooler.
  7. Method Race Wheels and lug nuts – 703 25MM off set Bead grip - $1300.00
  8. Window tint front windshield (lighter than factory) and front row windows (match rear factory) $250.00
  9. 3-year ceramic coat (2 years old) $1000.00
  10. Spray-in Bedliner (due to covid dropped off build sheet) - $550.00
  11. Ford Forscan mods – Bambi mode(fogs and brights can be on at same time) – Double Horn Honk disable – Enable Digital temps on gauge cluster – Disable fake engine noise – Glare Free Headlights
  • Monroney Label.pdf
slater
slater
Central US
Bump $68,500.00
Thanks, Gumby hope you are well!
Having to swap rigs for business purposes and don't want this sitting in the garage.
