thorleif
So when the FORScan tutorials say "Key on, but engine not running", is that the equivalent of the double tap on pushbutton for those of us that have keyless ignition?
crash457
I'm Batman
St. Louis, MO
Press the start button without the brake pedal depressed.
t_j
Chicago, IL
Can this be done on the 2014 Raptor?
---------- Post added at 02:03 PM ---------- Previous post was at 01:57 PM ----------
Do you need the standard or Extended License to do all this stuff?
Some can, but the info in this thread is '17+ specific check out the Gen1 thread for info for your MY. You need an extended license.
foo.c
Central TX
Hmmm ... I restored everything I touched and it still isn't locking. The alarm screen comes up but the doors never lock.
JetDriver480
Hey guys, just introducing myself here. Some of you may know me from the F150forum FORScan thread. Anyways, big fan of the Raptor & I'm pretty good with FORScan so I'll be adding this thread as one I definitely follow.
Welome. Whoever can figure out how to get the parking lights only as daytime running lamps I am buying you more beer than your liver can handle...
Livnitup
SoCal
Ford locked this down in BCM in the 2015-2017 years. Only way to have them on as DRL is in conjunction with low beam with this value:
726-26-02 x*xx xxxx xxxx DRL Include Park Lamps: 1=enable, 0=disable
lottp
Your support is always appreciated!
---------- Post added at 06:55 AM ---------- Previous post was at 06:46 AM ----------
Although not a FORScan soloution, have you seen any discussion on harness or relay re-wiring to electrically swap the low beam and parking lights when the DRLs are energized? I wasn't sure if it was completely internal to the ECU or not.
Mink
Oregon
I'm getting ready if my truck ever get's here. I have the scan tool and doing the setup and I think I've gone as far as I can without the truck. Question does the scan tool need to be plugged into the truck so I can get the Hardware Id # for the extended license? OR? Thanks
