lottp
I'm getting ready if my truck ever get's here. I have the scan tool and doing the setup and I think I've gone as far as I can without the truck. Question does the scan tool need to be plugged into the truck so I can get the Hardware Id # for the extended license? OR? Thanks
The hardware ID is for the PC or tablet you are using. You can get the license before you plug in.
Livnitup
SoCal
Your support is always appreciated!
---------- Post added at 06:55 AM ---------- Previous post was at 06:46 AM ----------
Although not a FORScan soloution, have you seen any discussion on harness or relay re-wiring to electrically swap the low beam and parking lights when the DRLs are energized? I wasn't sure if it was completely internal to the ECU or not.
I've seen something similar to what you suggested brought up in post conversations but I haven't seen anyone post that they've done it
Mink
Oregon
Thanks lottp, just needed that push to figure out what I wasn't doing. I'm ready now.
Jake17
★ REBEL LIFE ★
Had a buddy program the following:
front parking lights as DRL's (low beam OFF)
SPORT mode set to default
front windows up/down w/FOB
mirror spotlights operate at any speed
JetDriver480
Say what?!?!
If this isn't a joke we need the codes.
Livnitup
SoCal
There's no way this was done on a 2015-newer truck with FORScan. Sport mode as default would be something in PCM (if a value for it even exists) which FORScan can't even access. Mirror spotlights at any speed can only be done with hardware mod. I have another piece of software that does way more than FORScan and this isn't even possible on that so I'd love to hear details how this was accomplished.
JetDriver480
Auto Fold Can be done with the Key Fob but the rest is not possible to my knowledge:
Auto Fold Mirrors w/Key FOB Lock:
(Mirrors will fold closed via lock button on Fob but will only unfold when the driver's door is opened & closed)
DDM 740-03-01 x84x xx
DDM 740-12-01 Fxxx
PDM 741-03-01 x84x xx
PDM 741-12-01 Fxxx
The mirror spot lights can be jumped with a jumper to allow for use at any speed but needs the module near the gas pedal to be messed with.
Livnitup
SoCal
Global window open/close can be done with:
BCM 726-17-01 0101 0101 014A
BCM 726-17-02 0101 0101 014B
BCM 726-30-01 0101 xxxx xxxx
DDM 740-05-01 Dxxx xx
PDM 741-05-01 Dxxx xx
Jake17
★ REBEL LIFE ★
I'd like to know how this was accomplished.
Same guy got my truck delivered in early DEC.
Had his programmer hooked up for less than 30 minutes. Also installed a performance calibration (93 octane) > soon to be released by FP. Throttle response is much better, truck feels quicker.
I asked if a non-Raptor could have functional paddles shifters, he laughed, then finished his beer!
