crash457
I'm Batman
St. Louis, MO
If anyone wants to run Parking Lights (outer halo) as DRL this may work for you:
BCM
726-26-02 x1xx xxxx xxxx
726-50-01 017F
726-45-01 xxxx 7Fxx xxxx
Edit: 726-45-01 xxxx 7Fxx xxxx may not even be necessary for this to work, will verify later.
Does this leave the headlights on too or just the parking lights on?
Livnitup
SoCal
Just parking lights as DRL. If you want both low beams & parking lights as DRL just make this change:
For only parking lights as DRL just do the following (I edited my other post):
726-50-01 017F
lottp
726-26-02x1xxxxxxxxxx
726-50-01017F
You are the best! Doing this shortly!
pjones
So the parking lights will turn on as soon as the truck is started? Without turning the headlamp switch from off?
Livnitup
SoCal
This sets the parking lights as DRL in conjuction with setting the Daytime Lights on in the IPC menu. So if you have the type of headlight switch with the Parking/On/Auto position it would need to be turned to Auto. If you don't have the Auto position it should work in the off position if Daytime Lights is selected in IPC menu.
