Livnitup
SoCal
Thanks... So to get mine to use the parking lights only as DRL's in it's current state do I need to do just this?
726-26-02 x1xx xxxx xxxx (think this is already done in my vehicles condition?)
and then I also need to do this?
726-50-01: XXxx
Just don't want to screw anything up. I am familiar with FORScan but still makes me nervous unless I know EXACTLY what to do when programming. Thanks!
You'll need to set both of these (your truck won't have either already set this way)
726-26-02 x1xx xxxx ***
726-50-01: 01xx
Livnitup
SoCal
so what does the xx7F do in the 726-50-01?
726-45-01 xxxx 7Fxx xxxx - Allow all DRL choices
If the 7F there isn't set, then FORScan will give an "incompatible configuration" error when trying to write any of the following:
726-50-01 0280 DRL - low beams
726-50-01 0482 DRL - front fog lamps
726-50-01 0886 DRL - front turn lamps
726-50-01 209E DRL - high beams
726-50-01 40BE DRL - Low Beams and Dedicated DRL
I've edited my spreadsheet here to make the DRL choices clearer: https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466
---------- Post added at 08:13 PM ---------- Previous post was at 08:02 PM ----------
Sorry, I misread what you wrote. the 7F you're referring to is the checksum (the last 2 digits of any address are the checksum which is just a mathematical sum of all the prior hex digits in an address). FORScan will compute this automatically so you don't need to know anything other than to ignore the last 2 digits of any address lol.
Example:
If you tried to write 726-50-01 0199 FORScan would tell you there's a checksum error but just click continue and FORScan will automatically change that 99 to 7F.
Ironhorse07
Central, MT
Just parking lights as DRL. If you want both low beams & parking lights as DRL just make this change:
For only parking lights as DRL just do the following (I edited my other post):
726-50-01 017F
I used this one, and was just curious why this is changed to 762-50-01 xx7F. I think (like a ******* I didn't write it down) it was 0000 to start, and you only use the first two places with this new way. Just another way around the barn?
---------- Post added at 09:16 PM ---------- Previous post was at 09:15 PM ----------
726-50-01 017F
Example:
LOL, you read my mind, thanks
lottp
726-45-01xxxx7Fxxxxxx- Allow all DRL choices
726-50-010280DRL - low beams
726-50-010482DRL - front fog lamps
726-50-010886DRL - front turn lamps
726-50-01209EDRL - high beams
726-50-0140BEDRL - Low Beams and Dedicated DRL
Example:
Thanks for maintaining the spreadsheet! It's super helpful for everyone.
nick731
Great info and thanks Livinitup! You are a great asset to the community =)
Do you have to have 802a for auto-reverse side mirrors to work?
JetDriver480
Got my parking lights set for DRL's now... There isn't a way to do just the front end (and not the taillights and license plate lights are there?
Mink
Oregon
How important is it to save the original files?
I would think very important. I started from scratch today and the longest part of the forescan work was the backup.
A great big thank you to all the work livnitup has put into this, it all worked just how the write up's said it should thanks again.
