johnjoemd
HSWM: 714-02-010258585828 - full hot
BdyCM: 726-32-01xxxxx1xxxxxx - Dark Car enabled
You should have a button on left hand side of steering wheel that increases/decreases the distance it follows vehicle in front of you.
Awesome thanks man!
Yeah I know the buttons there I was just wondering if there was a way to make it even shorter than the level one is.
Livnitup
SoCal
Full heat on steering wheel? You mean hotter standard?
Disregard the setting for full hot on HSW, I just pulled a Raptor's as-built values and it's already set to that setting. Default is warm on 2015-2016 F150s so I assumed yours was set that way too.
pjones
That's too bad, because it'd be nice if it was a little warmer for those really cold mornings.
Livnitup
SoCal
Actually I found the following in my notes:
714-02-01: 0244 4444 xx - Wheel Temperature = 68ºF
714-02-01: 024C 4C4C xx - Wheel Temperature = 76ºF
714-02-01: 0254 5454 xx - Wheel Temperature = 84ºF
714-02-01: 0258 5858 xx - Wheel Temperature = 88ºF - Raptor Default
714-02-01: 025A 5A5A xx - Wheel Temperature = 90ºF
714-02-01: 025C 5C5C xx - Wheel Temperature = 92ºF
714-02-01: 025E 5A5E xx - Wheel Temperature = 94ºF
714-02-01: 0264 6464 xx - Wheel Temperature = 100ºF
* Higher temperatures may negatively affect the lifespan of your steering wheel's heating element so use at your own risk.
lottp
HSWM: 714-02-01 0258 5858 28 - full hot
BdyCM: 726-32-01 xxxx x1xx xxxx - Dark Car enabled
You should have a button on left hand side of steering wheel that increases/decreases the distance it follows vehicle in front of you when ACC is on.
In regards to the "Dark Car" setting, isn't there a dome light button on the overhead console? Is there a difference?
nick731
Hey @Livnitup, do you think it's possible with forscan to add/enable the tech package if we swap the right parts? (Adaptive cruise, lane keeping and auto wiper). Thanks for your knowledge!
