JohnyPython
Yea, better to have the entire frame rust in half instead of having mild surface rust on a cast iron chassis component.
This is a Toyota dealership.
Wow!! That's quite the graveyard.
I seen 7 frames all stacked on top of each other at the last Toyota dealer I drove by, lol. What a joke, why even have a crossbrace with that many f'n holes in it. Junk!!
No, it dries and stays clear, similar to a clear coat on paint. Looks great, shinny.Hi
Does that stuff turn amber in color once it dries ? I been looking to do that also. I have a little bit of rust also, but I want to nip it in the bud before it gets out of control. Did you spray your shocks and springs and plastics also ??
Thanks
Yes. Under the truck. No, it doesn’t look great, but it has no affect on long term durability.
The issue was actually with Dana Corp and not Toyota itself. Dana is paying for all of the rusted frames from the Tacoma, Tundra, and Sequoias that were recalled.
Yota outsourced the frames and undercoating to Dana.
I think just inferior metal, just like Toyota's logic.More folded and stamped frame parts than anything. Less heavy hydro formed and boxed. Wonder why they rusted through so fast. Thin gauge.
Thanks... did you have to use a special primer or cleaner first ? Did you do your shocks, springs and plastics?No, it dries and stays clear, similar to a clear coat on paint. Looks great, shinny.
Yes, I used this with a pressure washer. But honestly, I started the process the day after I picked up my truck. I was at the dealership when the truck arrived and drive it home, so it was very clean with very little rust.Thanks... did you have to use a special primer or cleaner first ? Did you do your shocks, springs and plastics?
