Frank N
are people still here ?
Yep, people are checking in on the car wreck...
Might want to go back and re-check your math there. The 6.2L V8 is a 2V engine. The 3.5L V6TT is a 4V engine.
Even with two less cylinders, the V6 has 50% more valves, springs, retainers, followers, valve guides, valve seals, and valve seats to fail. Plus, there are twice as many cam sprockets, timing chains, chain tensioners, cams, cam saddles and cam covers. Let's not forget those V6 cams are two-piece cams. The total just for the heads is at least 100 more parts. Then you get to add all the turbo stuff and the direct injection fuel system.
The only thing the 3.5L V6TT has over the 6.2L V8 in terms of simplicity is one spark plug in the V6 vs two for the V8.
It's not so bad when compared to a Coyote engine, as those are 4V engines too.
It doesn't speak well for the V6TT that all of those extra parts, a complex fuel delivery system, plus a crap ton of boost generates less than 10% more power than the 6.2L V8.
Now if you said we are ALL going to have to get used to fewer and fewer gas powered vehicles in the future, that I would agree with.
No doubt about it. If they put they same level of tech in the V8 it'd be a 800 hp engine. But it would be less reliable.LOL. Didn't realize the 6.2L was so primitive. No wonder it makes so little power per liter while devouring gas at a frightening rate.
Im sure a vast majority of my neighbors prefer the sound of the Raptor at 5am to the V8.
