Fender Modification to run 37's with 1.5" Collars
tomtom
Calgary
Would love to do this mod but don't trust my fabrication skills enough to cut up my ride.
rsbug
N Texas
Excellent write up, something I’ll do eventually. 37’s look great!
BBLV
Newport Beach
I went to 3 different welding supply shops and struck out and wasted too much time online looking for less than 30lb of ER5554 with no luck... Any tips on where to find a pound or even ten of filler rod at a reasonable price?
MEATSWORD
Arizona
You maybe able to bend or otherwise hammer that lip over, Not sure how the aluminum would like it tho. Might get you close?
PCDan
Park City
Looks really good for clearing the rear fender rub, best I’ve seen, but with 0 offset wheels the 37s will still come up into your fender flare if you take a suspension hit with the wheels turned at all, thus the need for aftermarket fenders.
I do like the look of 37s, but per SVC and TMX in the absence of being paired with fenders so the suspension can flex, it’s an appearance mod, not a functional one.
jwpres
jwpres
Tempe, Arizona
If I were you I would use the wire you have, Im sure it will work fine.
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
You are assuming zero offset which is also a purely cosmetic ******** mod which spews crap all over your truck and rubs like shit. After running 35s on methods for years I am thinking 37s on stockers is a much better mod.
