Nearly Level From Factory: '24 on 35's
Andrewalker7
I could not find this mentioned, after some thorough searches.. but forgive me if this has been covered.
I picked up my new 2024 801a in November of 2024, with zero modifications done by the dealer.
With that, I've noticed slightly that the front rake isn't substantial, which I certainly don't mind.. but that means my rear lowers quickly with any real loads. I've looked just as thoroughly underneath, and at all suspension components. Nothing stands out as non-OE.
With only ~70 lbs. in the bed, and nobody in the truck, my rear fenders measure at precisely 41". Fronts measure at 40 5/16". Is this "normal" to be this close to level from the factory?
Especially since some of the springs and kits to level the fronts appear to advertise 1-1.5" of front lift, this seems like it would raise mine much higher than level, with that math.
Reason I'm asking is because I see a handful of Raptors around (and on FRF) that appear to have much more front rake than I.
I don't notice any premature wear or sagging of any kind, and the right is superb.
Any insight, or even measurements of other Gen3's would be helpful. Thanks!
shigman
Cypress, TX
Mine is pretty darn level, but I have hauled some heavy loads which I think settled those rear springs. Is that 70lbs near the tailgate or up by the cab?
Andrewalker7
Andrewalker7
Good question- entirely at the tailgate.
I towed ~3k lbs last week with a standard B&W hitch, and while I had a bit of sag, it wasn't tremendous.
