Fender Modification to run 37's with 1.5" Collars
Booth9999
Idyllwild
Here I have re-bonded lower lip of fender
Modifying Fender Flair
Heat is used to reshape flair before bonding it back together
Backside of the repair
Outer repair ready for paint
What product did you use for re-bonding and filling on the plastic? Great job.
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Great thread, thank you.
Do you think those of us without the facility to weld aluminium could use an acrylic structural adhesive like the Norton Speedgrip 6420? I feel like it would be likely to separate.
Wfo
Syracuse
I wouldn’t risk it. Have it tig welded, not worth the risk of it separating.
Kahuna
I suspected so. I've just never worked with these types of acrylic adhesive and our tinfoil panels before. Thanks.
jwpres
jwpres
Tempe, Arizona
I agree, It is definitely a structural area so I wouldn’t take a chance. I mig welded the filler piece I made. You should be able to find someone to do that for you very responsible.
Wfo
Syracuse
I was going to mig it myself but the cost of a new spool of aluminum is more than the couple beers my buddy will Tig it for.
Kahuna
You should offer this as a service through your shop. It really is a game changer. Removing the need for glass fenders for many and the quality of the output is fantastic. Certainly beats most versions of this which look like a bad attempt at carving a Jack Skellington jack-o-lantern.
