yoursmiledoc
- Joined
- Oct 19, 2014
- Posts
- 15
- Reaction score
- 0
I am previously the owner of a 2011 Raptor crew. I decided to build an ecoboost raptor. I bought a 2012 FX4 crew in silver, the same color as my old raptor. I bought RPG's complete front end. ( UCA,LCA,tie rods) and some raptor take off shocks. I had all of that installed last week. Of course the turning radius was cut down to 18 degrees in each direction on my "Off Road truck app". I searched online and called RPG. After grinding the bumps on the lower arms I am able to get 24-25 degrees in each direction. This still seems like much less than stock. When I look under there it looks like the tire will rub the UCA if it turns any sharper.
Here are my questions:
1. How sharp does your stock raptor turn in degrees?
2. Has anyone swapped the RPG UCA's alone and still kept the turning radius?
3. I have the electric rack. Does anyone know if perhaps it does not have as much throw as the hydraulic rack? Since the spindles are the same as before, it seems like it should steer the same.
I am still running the FX4 wheels so the tires rubbing the UCA may be a backspacing issue.
