Wilson
I made this for Memorial Day will use it when ever I can. 4th of July and so on.
2"x2" square tubing about a foot long drill a hold basically it is a receiver hitch. torch a hole big enough for a 1" pipe weld into hole. I welded a old bearing on top with a old nut welded on to the bearing for the cairabein to attach to if you can find a big enough on for easy attaching to the pole I used a u clamp for now. will keep looking for a big cairabein. spelling
edit: I used flag rope to bottom of flag where the U clamp was it was way quieter and fit over the top of the pole.
