CNG cylinders
The thing about Compressed Natural Gas (CNG) is that even under 3000 psi, it remains a gas at normal temperatures. This is because it is mostly methane which is the lightest form of hydrocarbon. Propane is much more dense and liquifies under a tank pressure of only a couple hundred psi. Octane (gasoline) is many times more dense and is a liquid. A typical CNG cylinder might hold 18 gallons of water but pressurized to 3000 psi would supply the same fuel as 4 1/2 gallons of regular gasoline. Two cylinders stacked at the front of the box gains you 9 gallons (typical max setup). Even if you have to use a little gasoline every day, remember that the first 9 gallons is cheap Uncle Sam's fuel and that other crap is expensive Saudi or BP stuff. As for the fill-ups being variable, it matters what temperature it is when you fill up. Remember I said that it is always a gas. That means that 3000 psi at 70F is the same as 2000 psi at 0F. And since the CNG fuel gauge is a pressure gauge, it looks like you drive away with less fuel when its cold out because the station doesn't give you a full 3000 psi at 0F so you can't then park in a warm garage and have the 3600 psi relief valves start blowing overnight.
