CNG conversion for the 6.2L?????
ISFast
ISFast
Tulsa, OK
I would guess it takes up about 1/5 of his bed. He's mentioned the pressures at the refueling stations are inconsistent and it's hard to get a complete fill sometimes. He gets about 150 miles out of a full tank of CNG, then he just flips a toggle in the cab and goes back to gas.
That clears it up a little bit more thanks!
JP7
Likes Canadian Mudbaths
Calgary, Alberta
Well shit - there goes my idea for filling the old gas tank with Jack Daniels and using a windsheild washer pump and lines up to exit under the dash....
PEZ
Morgantown, PA
And what happens if another car or truck hits you when you got a big tank of CNG in the bed! KaBOOM!!!!!
We can do it
We can supply you a installed system for your 6.2 raptor we offer the highest quality bi-fuel systems on the market. If you are in edmond ok we also have a dealership that will back your warranty running your Cng converted raptor. Give us a call or come by our shop
Ruger
Northern Nevada
Wow that's heads-up marketing, CNG Interstate. What did you do, Google CNG, find this thread, and join the forum just to make that post? Impressive. Welcome to the Ford Raptor Forum. Stick anound long enough and there will inevitably be a Raptor in your driveway!
bassassassin
wisconsin
It's not CNG but Roush has a propane setup for F-150's to 2008 and may be coming out with a setup for the newer trucks in the future. The only downside is you can only run propane.
JP7
Calgary, Alberta
And anyone who's run propane trucks knows winter is a different animal with them. Extreme cold can be an issue (or used to be 10 years ago).
bassassassin
wisconsin
The Roush system doesn't use a mixer. It uses fuel injectors and rails that replace the factory ones that are designed for gasoline. So maybe cold wouldn't be a problem. The big problem is the price$$$.
ISFast
ISFast
Tulsa, OK
Where are you guys located at and how much does a kit run?
