CNG conversion for the 6.2L?????
havana
running on cng. power feels the same. big smile driving this truck over my 6.2 f250. you know how these things go. delayed getting it in,took longer than anticipated,unforeseen things at the end. the 24 gge type 4 tank on bottom is running the truck,still waiting on a valve for the 14gge tank on top. some new dot rules this year require venting the valves on enclosed installs. the 24gge tank barely fits between the bed rails but does not extend above the bed rail top. was told the installed injectors were larger than normal and two regulators were installed to feed the injectors. regulators installed low behind the grill. so much for a rigid light there. the fill nozzle is inside the fuel fill door above the gas cap. i'll report after some driving
Sooner Raptor
OKC
Thanks for the update Havana. I went ahead and put down a $250 deposit to take advantage of the March madness special with CNG of OKC. My truck is being built as a speak. So I have till early May to back out if you report any flaws in your setup. I opted for the 24 gallon tank. Do you know if a Bakflip cover will fit on the Raptor after the conversion? Sucks about the grill. I guess a "20" under the license tag or a light bar on top will have to do. The Oklahoma 50% tax rebate will hopefully pay the conversion off in a little over a year.
havana
the 24gge tank will require some modifications to your inner fenders(performed with a 4# hammer). not a biggie but be advised.
havana
couple thousand miles running cng. had a check engine light come on once. after a strong rain. went off after a few driving cycles like the book says. getting 15 mpg highway and 12 mpg avg on display. power seems only slightly less which is expected. $1.40/gal fuel
sabumaru
The Netherlands
What does gallon of 93/95 cost
I am dutch
For us its €1,70 a litre for 95 octan
And about €0,70 for LPG
Cng is not realy commercial here yet
