Cleave
No, it wouldn't be cheaper, I never said that
I gotta say that the cheap and easy way is not the direction you're heading with your build already, which would be the direction you would be heading it towards if you put an ls motor in, just get a built aluminum or titanium block based off the boss 6.2l, bored and stroked to 7.0l, it is a better design than the ls motors, just no one has taken it even near it's potential yet, remove the 4x4 system, but I'm not going to say removing the bed is a good idea, it's a pickup truck, people add weight to the rear end of drag trucks for a reason, get it weighed with scales at each wheel and remove and add stuff until you get a balanced weight distribution both front to rear and side to side, doing the weighing with you in the driver seat or something that could properly represent you would be the best way to do it
Instead of buying useless carbon fiber parts you might want to save your money for a lawyer if/when your Hennessey Performance Veloci"RAPTOR" 800 catches fire and burns to the ground.
Just found this
http://www.hennesseyperformance.com/62raptor800.html
The discussion about the LS7 pr Titanium block is kind of irreverent given that the engine was the first thing built. It's done and is not going to change. Tons of power and I;m perfectly happy with it. Could it be lighter? Yes but throwing $100k out the window to save a few pounds would be ridiculous given that weight can still be shaved off in so many other areas.
A.I.I., your suggestions have been genius and given me a lot of great directions to go in. Thanks so much. Keep it coming ;-)
