Carbon Fiber Body Mod
justvettn
GTA
The engine is a major place to save weight, and that could be done without giving up the modifications you already have put into it, going with an aluminum or titanium engine block built to the specifications of a standard 6.2 would just require swapping all the other engine components over to the new block, a sleeved aluminum block would be the best option for maximum weight savings
I can't believe you are still referencing titanium engine blocks.
MagicMtnDan
Magic Mountain
OK, if you spent $100k on the motor and you want your pickup to have more speed here's what you should do:
1. Remove motor.
2. Have an all-new, tube frame truck built by a racing company.
3. Have all CF/FRP body and interior made.
4. Your formerly 6,000+ lb. truck should now weigh about 3600 lbs.
5. Put a 6.2L factory motor in your Raptor.
6. Sell the Raptor and use the money for steps 1-5
:party36:
sabumaru
The Netherlands
1. Remove motor.
:party36:
I understand what you are saying
But i think a tube frame and custom interior will make it more into a prerunner / trophy truck imo. On the inside in mean
I would luv to get me something like the atlas concept has
KaiserM715
Kaiser Söze
Even if money was no option, Ti wouldn't make for a good engine block. I also doubt it would be lighter. Per volume, aluminum is is roughly half of the weight. Given all of the bosses, bores, mounts and coolant and oil passages, I doubt you could significantly reduce the volume of metal used in an engine block. Not to mention that Ti is bear of a material to machine and has significant galling issues. With a part as machining intensive and complicated as a block, you would have a high scrap and tool breakage rate.
If you really wanted a lightweight block, magnesium would be the way to go (and has quite a bit of historical precedence).
Maxx2893
Rock and Roll Offroad
Burleson, TX
Swap bumpers and rack for lighter weight ones. Those iron bulls/ fab fours are extremely heavy, you can get great looking prerunner bumpers that could easily save 100+ lbs on each end. Plus a lighter rack, who knows how much that rack weighs.
justvettn
GTA
I have not researched the latest and greatest in engine blocks but I am sure that Titanium for several reasons would not be one of them.
I also highly doubt that any manufacturer would even consider doing so for any reasonable amount of money. Even if someone was willing to attempt it the cost would be $100,000.00 or more (Just guessing due to the cost of titanium and its difficulties to work with it) just for the engine block.
Titanium is also heavy in comparison to aluminum.
Maxx2893
Burleson, TX
He could use titanium internals. Lighter weight, and that's weight that's moving very fast. Might check out Crower to see if they have anything.
sabumaru
The Netherlands
On the exoticmside of materials
The material the spaceshuttle heat tiles are made of :)
Or the aluminimum/carbon hybrid stuff theynuse on the airbus a380
---------- Post added at 06:42 PM ---------- Previous post was at 06:38 PM ----------
http://www.emachineshop.com/machine-shop/Custom-Titanium-Parts-Machining/page465.html
---------- Post added at 06:43 PM ---------- Previous post was at 06:42 PM ----------
http://www.delwestengineering.com/parts_titanium_valves.html
