FordFanStan
- Joined
- Oct 18, 2010
- Posts
- 458
- Reaction score
- 236
Correction, I think I did have to remove the sensor when I installed the RCV IWE eliminators. Then that’s when it first tripped.
The fact that it didn’t set the DTC while lifted is a good indication that the tone ring is shifting when the vehicle’s weight is applied to the wheel bearing. The tone ring is integral with the wheel bearing within the hub assembly.After cleaning off the hub where the sensors are seated, I cleaned all the brake components of the extra grease from the initial install and re-installed them. I tightened the rotors down, put the entire truck up on jack stands, put in 4wd, and brought it up to at least 15mph. No code. I was ecstatic. Mounted wheels and went for a test drive and as soon as I was near 15mph it tripped the C1296 code again and all the dash lights. This is very aggravating.
Is the tone ring permanently affixed or mounted inside the hub?
Is there any way I can test the wiring up to the sensor plug maybe?
