Heya! So which willwood kits are compatible with Raptor R?MAP is $438 front and $389 rear.
It's very straight forward. The brake maintenance mode is only needed for the rear because of the EPB, not the front so you're all good. You will need to bleed brakes once you're done since the front lines get replaced with the new kit. Feel free to reach out if you have any other questions.
