Big Brakes
Redwood City, CA
Have only driven back home from the shop, but initial bite is better for sure. Much firmer pedal feel and more confidence that the big bus will stop when needed.
Also, looks cool..
blwn
Florida
Also, looks cool..
Not positive, but looks like your rotors may be on the wrong sides..
And that is a lot of wheel weights
Nick@Apollo-Optics
Nick, I'm curious about the fitment on the 21 and 22 trucks, were these with
the factory beadlock wheels or aftermarket. As I indicated previously the template
dimensions from Wilwood will not work on factory beadlocks!
Fortunately, @Andrew Macpherson just shared some pictures below confirming fitment with the OEM beadlocks on the Gen 3 trucks. I quoted his post below.
Looks awesome, man. Thank you for sharing!
Strange, ever other type of slotted/drilled rotor has it facing the opposite direction
I had to do a double take on that as well, but it is correct for these Wilwood kits.
tominphx
phoenix az
Yes, looks awesome......
Wish I could have figured out the fitment for the Gen 2 trucks, wonder if the inner barrel
dimensions of the wheel is different Gen 2 to Gen 3.
Nick@Apollo-Optics
