Actual mpg change: 37 bfg
Truckzor
The BFG 37s are ~ 6% larger than stock so if you are going an indicated 450 miles on 30 gallons for a reported 15 mpg you would actually have gone 477 miles on 30 gallons for an actual 15.9 mpg.
So if you're quoting MPG without having corrected your speedo...
:specialed:
DEGBTI
San Diego
:specialed:
sweet, thank you! not as bad as I thought
grantoser
grantoser
:specialed:
Very good point here....
ChevyChad
I accounted for the discrepancy in my calculations. Still got 1-2 MPG worse with heavier wheels and 37" tires.
Truckzor
I’m thinking 1-2 less would be lucky.
37" BFGs aren't that that much heavier than stock. There's no way, all else equal, anyone is losing much mpg over stock with them.
Most (all) of these guys reporting reduced MPG failed to adjust their speedo or account for that difference in their "analysis".
ChevyChad
I calculated mine correctly. Here are my results for 87 octane for both:
Stock: 34.4" tire height, 95.2 lbs wheel and tire (measured on a scale)
sample A MPG readout on dash: 16.5mpg
sample A actual miles traveled: 372.0 miles
sample A actual gallons at fill up: 24.393 gallons
sample A actual MPG: 15.25mpg
Aftermarket Nitto Ridge Grappler 37"x12.5" on 20"x9" fuel vapor wheels: 127.2 lbs wheel and tire (measured on same scale as stock on the same day)
Sample B MPG readout on dash: 13.2mpg (this would probably have been 14.2 had I changed my speedo)
sample B miles traveled per uncorrected speedo: 396.4 miles (actual miles traveled was 426.36)
sample B actual gallons at fill up: 31.235 gallons
sample B actual MPG: 13.65mpg
Actual difference of 1.6 mpg on that particular comparison which was as close as I could find in the samples I took for my own comparison.
And as you can see, the mpg reported on the dash is a ballpark estimate at best. To get a true MPG you need to calculate yourself.
Go ahead, poke a hole in my "analysis". I'll wait.
Truckzor
Truckzor
I was replying to your following comment:
:flipthebird:
I guess you missed the part about the 37" BFGs?
I repeat. Come on man.
:specialed:
