Does the 2013 have a harder roof? What about sunroof models?
The one we drilled into was a 2012 with a sun roof.
On 2013 I think they took the reinforced metal out of the roof and put it in the frame lol. J/K
I am confused. At which point in this thread did we go from 2013 frame reinforcement to roof reinforcement?
Frames between Raptors and the rest of the F150s are different. Since the beginning they have always been different. Adding extra metal to the bump stop area of the frame is just evolution. All models evolve over time to improve on the original design. Won't make the 10 thru 12 model any less desired because the opportunity is there to improve the frame with aftermarket support. Same frame supports that the 13 will need anyways once pushed hard enough.
Hmmmmm time will tell. I say different about the resale.
+1. I throw the ******** flag. Cab is standard F150. Interior changes mean **** for the frame.
I doubt that. This far up the frame wouldn't be part of the engineered crash protection.
Maybe slight resale to some buyers, but overall I just don't see it. The latest models usually end up being worth more because most of the time they have less miles, more options not offered prior, and are younger in age. I don't see that being any different for the raptor since there's nothing immediately wrong with the later year models. So sure a 10 will most likely resale less then then a 13. I think potential buyers will fall into two catagories when it comes to the frame, they either A) won't care because they don't push the truck hard enough to have issues, or B) know they will push the truck hard and opt to put a bump kit/frame support regardless of year. The real factor might lay in how much support the new metal actually helps. If its only adds a slight amount of strength, is it really worth it tracking down a 13 and later?
