Snowsled
I'm looking at high-mileage 2011s or 2012s. All I can afford.
You are very likely to find the same problems on a newer model year, there were not a lot of changes or real chronic issues with any particular year. Buying them half worn out of better is what leads to the repairs you experienced. Buying high miles again is very likely to put you back in the same boat.
You have already experienced buying one on the cheap and having to fix it. Now you are under the impression that buying a slightly newer one on the cheap is going to cure that problem? I seriously doubt that is going to work out in your favor. You will most likely end up with the same issues.
Just save some more and buy a decent one. I picked up a clean 2010 and do not have any real issues with it at 100k miles. I will have to rebuild the front end like you did and I need to replace the third brake light but I think you should expect such things on any older used vehicle.
