Upgraded IWE
If a full time hub was available for the Raptor would you upgrade?
  • Total voters
    163
WyoStorm
Wyoming
I was curious about yours ironside as I know you have a lot of miles and plenty of off road and snow miles. That's a good sign. I've always learned to take great care of my 4x4s and I hope I don't have any problems either. It's especially good considering all your mods and everything is still good.
Yukon Joe
Trafford, PA
Subbed to see about a fix for this issue.
I know I have been lucky my 4x4 still works good. I get slight slipping, and have had a cluck maybe 5 times in the life of the truck im at 80k Miles now I'm thinking maybe I should go get it checked out by the dealer before I go out of my extended warranty
Take it in before trr.
Yukon Joe
www.RUNRAPTORRUN.com
SuperRaptor
Seattle
We looked at that option even calling Borg Warner about making manual locking hubs. Borg Warner said no reason to develop a manual locking hub, their system works as designed.
If the IWE was on the outside of hub it would be easy to make a manual lock. Since it is on the back side of wheel bearing there is no way to access the stupid locking ring from the front.
I went as far as getting a f250 hub with manual locking hub and trying to figure a way adapt it to f150 spindle/upright and axle.
Going to talk to RCV about changing out the outer part of the axle to a fully splined outer axle. If this is possible, then might be able to make it manual locking hubs with already available off the shelf products.
Something like this.
-Greg (aka Squatting Dog)
While I am no expert nor an engineer having a fully splined outer axle would net you the best of both worlds as I see it. I for one would hate to always have my hubs engaged but could live with having to engage them when I wanted to be able to shift in and out of 4wd.
M1919A2
Could you add an outboard manual locking device?
You could have both, for light duty you would rely on the inboard locking but for serious off-roading you manually lock the hubs.
Like the F250/350 4x4 Super Duty does!
---------- Post added at 02:55 PM ---------- Previous post was at 02:50 PM ----------
In fact, I've been looking at the 6.7L Diesel in a SuperCab F350 4x4 with 142"WB
And if you aren't into "Jumping" a 3 ton vehicle
It's looking better than the Raptor all the time!
Rorywg
Dubai
This looks great. While i am waiting... I have removed the torsen and put in a locker. And a pair of new IWEs as the last two blew. I have no idea if this will fix my ongoing problem...please make haste to get your upgrads in production, i am birning money on the old stuff!!
Squatting Dog
Squatting Dog
Kansas City, MO
If you get a chance can always call RCV and let them know you want the IWE upgrade. Let them know there is a demand for this product or solution.
Sean M. Carlini
Director of Product Development
RCV Performance
www.rcvperformance.com
tel (815) 877-7473 x 5706
fax (815) 877-1218
phydough
Looks good except for not being able to use stock wheels. Why the new inner axle shafts?
