Which Intercooler to get?
Mbdurham
Georgia
I am deciding between Cobb and Full race myself as i most likely going with a Frame cut bumper installed at the same time but even if I go bolt on I will put lights and block the intercooler and want the most cooling possible
Any pros or cons with either?
Nick@Apollo-Optics
If you go Full-Race, you'll need to purchase an additional bracket for ADD Frame Cut bumpers. The Full-Race Intercooler does not sit high enough for the ADD PRO or ADD Rock Fighter Frame Cut Bumpers. The additional bracket is $295.
Mbdurham
Georgia
Thanks Nick. Am I correct in that with the Cobb I would also need the ADD ACC relocation bracket but the Full Race has it included? Also any difference in amount of required modifications to shutters and grill between the two?
Nick@Apollo-Optics
With Full-Race, you would need to add the $300 bracket I mentioned before. But it would have the ACC mount included.
With COBB, you would need to add the ACC mount which is $150, but you would not need the modification bracket for the FMIC like you do with Full-Race.
Modification is pretty much the same between the two. COBB is a larger intercooler and is available in black with no upcharge.
Mbdurham
Georgia
Gotcha thanks Nick!
nikhsub1
Los Angeles
Modification is pretty much the same between the two. COBB is a larger intercooler and is available in black with worse cooling.
FIFY :)
