What weight dist hitch is everyone using?
ssj4sadie
San Antonio, TX
Well that sucks. I have apparently a lot to learn when it comes to towing something properly. I was/am planning on towing various rented travel trailers and bass boats. So I will never know the exact tongue weight until I rent the item. Was hoping to just buy the "the biggest WD hitch" and call it a day...
vr4henry
Here's a ~4500lbs trailer w/ 450lbs tonque weight (Sherline scale).
No WD hitch usable on my Trailex aluminum trailer (racecar inside). Raptor ended up pretty level (.25" higher ground to wheel arch in front).
~2" drop in rear. Zero issues towing. 100x better than my old Suburban 2500.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
Can you do a weight distribution hitch on a boat trailer? The long straight tongue may be a problem. Other trailer have a V shaped tongue allowing the weight to be spread side to side. Never seen one on a boat.
Jspeers89
Geo_Tactical
Idaho
I've heard great things about blue ox for heavier loads (4000-8000) and Andersen for medium duty weight (4000-6500). How much does your trailer weigh Geo. I've been torn between these two for quite some time.
Fully loaded it weighs about 4k. Regardless of weight stability, one of my favorite things is being able to back up and turn without all the poping sounds you would normally get with a wd system
Sent from my Galaxy Note 8 using Tapatalk
