What did you do to your Raptor today? (Gen2)
Nex
RIP CoronaRaptor
Washington State
Is your tank an Amazon parts kit you put together? I’m wanting to do that. I think Keep it Dirty had a YT video with links.
The regulator is from Amazon, the tank is from a local welding shop. Part of their exchange program so I always have a tank in in certification.
Old-Raptor-guy
USA
I have the same set up, except I have a second tank in the garage at all times. With the F350 airing up 35" tires from 25 to 70 would drain a tank in two trips and I was always rushing to get to the welding shop before another outing it seemed.
With Raptor going from 17psi to 35ish, the tank lasts about 10 trips.
Sig Fanboy
WV
Sweet, I have lots of Oxygen and Acetylene bottle for my business through a local welding supply business, I’ll ask if the have Co 2 tanks I can add to my account. If you have a link for regulator that would be awesome. Nice looking set up. Is that a 10lb bottle?
Nex
RIP CoronaRaptor
Washington State
Yes, 10 pound bottle
Adjustable High Flow 250 PSI Carbon Dioxide Co2 Regulator and Handle Kit for Jeep Tires - Be sure to check your cylinder for proper fitment - see description https://a.co/d/hC8t7gP
20' Polyurethane Braided 250 PSI Working Pressure Coil Hose with 300 PSI Quick Connect for Air Tools https://a.co/d/fpl9a3F
JACO FlowPro Digital Tire Inflator with Pressure Gauge - 200 PSI https://a.co/d/gLB3DWK
Looks like the bracket I bought is no longer available but there are a number of them on Amazon to choose from....
Old-Raptor-guy
USA
Once you go CO2 I can not imagine going back.
I have a this. https://www.amazon.com/dp/B078W2FZNZ/?tag=fordraptorforum-20
I have a mechanical gauge I put in the middle port. (No batteries).
On the center inlet port I put a shut off valve.
The two outer ports I have hoses going to two tires ( F350 I did front to rear different psi, raptor I do same psi all around so I hook to one front and one rear at a time)
To air down, take about 3 minutes a side (Raptor)
To air up takes about 45 seconds to 60 sec a side. (F350 was about 90 seconds)
Previously on the F350 with ARB compressor was about 7 minutes a tire.
(Will possibly post picture tomorrow, but tons of YouTube videos about airing down on jeeps)
