mprice1234
SVT Gen 1 Rules
Don't you just hate when what should be a ten-minute simple job turns into one major POS to do!
I can’t get anything off except the black plastic cover. I seem to have two choices at this point, leave it alone or cut the whip the length I want it.Are you able to remove the entire antenna assembly off of the fender? Disconnect the cable and then be able to work on it on a bench. Soak the entire thing in a jar or maybe carefully add a little heat to the antenna close to base without ******** up said base.
Yes. And my personality doesn’t like being beat. I managed to refrain from getting a saw out…so far.Don't you just hate when what should be a ten-minute simple job turns into one major POS to do!
Time to break out the plasma cutter!I can’t get anything off except the black plastic cover. I seem to have two choices at this point, leave it alone or cut the whip the length I want it.
My brain is quietly saying “What’s a little more body work? Cut the wire, take the whole thing off and repair the hole.” Problem is I would likely have to grind the plate off because the three screws won’t even turn.Time to break out the plasma cutter!![]()
