dj30417
CRZYCHK
Your basement
I am finally doing this, shock replacement. I need some help.
I want to replace the entire unit, spring and shock, this is what I’ve found so far but when I click on the link for the complete front kit I get a list and nothing in the list on the connecting page are what I need.
**What do I need to order to get the springs and shocks and everything else all in one?**
**Is there another company I should be looking at?**
As you can see, I waited a few days too late to use my discount code.
BTW, this is what I do when my dog wakes me up after I’ve slept my obligatory two hours.
As always, all help is greatly appreciated.
TomDirt
Hesperia CA
Are you re-using the oem coils? Are you going to have the Fox valves replaced with Schrader valves so you can get them charged anywhere?
TomDirt
Hesperia CA
Might want to also swap out the UCA's too. They are NOT subject to "Raptor Tax" (and the balljoints aren't replacable).
Irregular F150
its terrain good sir!
Where i got all my suspension parts I couldn’t find on rockauto.
May have to adjust the year and screw/scab part
CleverGirl_
Cabin Clown
Whats the best way to remove the oem valves. I am going to do this on my next set.
dj30417
CRZYCHK
Your basement
I want to replace the coils with new ones. I’m sure I have read about changing the valves but I hadn’t given that a thought.
Thank you for this suggestion. I’ll bring it up to my mechanic.
Good, this is what I need to know, a place to get the rest of what I might need.
**If there’s anything else I need to know, please keep the information coming. I have some time to get everything together.
BenBB
Lots of different places
Factory isn't so much a valve as a little rubber pellet...removal is relatively easy, I used a needle from Schmidty and threaded on a ball valve, the nitrogen (if charged fully) is under 200-240psi so exercise caution heh, once discharged just dig it out with a pick or something. The charging is the fun part and the reason the Schrader valve is so much better than the stupid needle and pellet setup, for that you need nitrogen tank/regulator/hose/chuck or have a shop/buddy do it. Found a pic of the tools I built/used for the rebuild a few years ago, the needle & valve is in the center (I got schraders from Forged back then):
CleverGirl_
Cabin Clown
Thanks! We have nitrogen i was just wondering how to get the old stuff out
