WHBD
MD
Standard published minimum contract specification requirements. 64lpm, SNR 25, Halo max of 1, EBI 3. Those are the numbers I look at. In reality, most Omni-VIII tubes I've seen perform way better than that. I'd have to send those into Ident Marking to have them tested for actual specs.
That's your new one or your old one?
TomDirt
Hesperia CA
How about a pic of the whole truck to see how that looks
I want to see how the exhaust got there without wrapping under the frame..... (unless you hack through the bed and go over it)? I've got the MBRP dual tip exhaust on my '12 ecoboost and it has to hang under the frame rail to exit in front of the wheel. I wouldn't do that for a serious offroad truck because eventually you will crush the tubes against the frame or tear them off; both are unacceptable risks.
TomDirt
Hesperia CA
That pile of metal used to be the D-side coil bucket.
And those are oem vs KHC vs new UCA bolts. The new 12point are 3" shank, (next length available is 3-5/8" shank, is a bit too long), and rated at 175000 psi.
2012SCSVT
CA
Are you bolting in the coil bucket? Those 12pts are nice... but why select black oxide finish?
