SVT Guy
Houston, Tx
Plastidiped the yellow parts of the stripper pole. Ran a small self tapper through the bakflip hose to keep it attatched.
Sent from my SM-N900T using Tapatalk
The Macf
Vegas
I detailed the engine bay, while spraying plastidip on my grill/front bumper/rigid d2's. I also blacked out the front amber marker lights with Nightshades. You can see my skid plate, which I also dipped in the background. Busy, busy, busy.
I didn't clean the air filter, I know there mud on it, one thing at a time.
What did you paint on your rigids?
TheJoker
N. E. Massachusetts
The lights were starting to show some corrosion and the mounting brackets were starting to rust, after almost 2 years on the truck. Now they look like new, minus the chrome allen bolts.
Yukon Joe
Trafford, PA
WSI 2 tire rack (DIY edition), after a test fit with some tires in I realised that the hi-lift would not fit across the top of the back rail and still allow the cover to close. Looking around at the left over sections of tube from finishing/notching the rack I worked out that I had enough to build the small bar off the front of one of the sides. So I joined two sections (well a pipe fitter friend of mine did that weld) of cut off end to end, notched it and tacked it in place, then notched one of the smaller cut offs as a brace, tacked that, then welded it all in place with some pointers from a friend that works in race fab shops.
I already had the hi-lift 1-2" tube mounts that I wanted to use, so I cut some tabs from 1" angle to use as the mount points as the tube clamps would probably just slip round. Then I drilled the bolt holes, clamped them all to the new section of tube welded up the sides of the mounts trimmed them and the welded the back side (not that it was required for strength just looks).
Rack was then finished with rustoleum bed liner rattle cans. After paint the hilft mounts were bolted on using some fresh grade 8.8 hardware (I may upgrade this to imperial grade 8, as metric 8.8 is closer to imperial grade 5).
Today I think I will CAD up an end cap for the tube so I can print it on the 3d printer next time I go to the workshop, that and install the bolt covers that I printed for the bolt heads attached to the bed bolts.
Nice. Need some pics.
aaah, yea i get it
just don't make this mistake :)
Verstuurd vanaf mijn GT-P3110 met Tapatalk
Whoever did this to this truck, needs to be tied up over a Texas Red Ant mound, stripped of all his clothes, and have a dollop of honey strategically placed over their taint!
I know, right? The guy forgot to match the mirror deflector red as well. Geesh.....
Installed a Volant CAI a while back, as every one knows that installed a CAI, the heater hoses are no longer supported being the airbox/throttle body resonator is removed that holds the factory hose bracket,today I noticed the lower hose with the mesh on it put a wear mark in the sparkplug wire (PIC-#7 ),and before it cause's damage , I wasted some time and desided to make a heater hose bracket, utilizing the valve cover studs, just have to paint it.
Nice bracket. Could probably sell those. Lol...
Does anyone know where exactly to get the billet mirror reflector replacements? Can't seem to find them
Sent from your girlfriends closet
Billet? Or are you talking the black ones? If so they are plastic Ford part. About $12 a piece.
Yukon Joe
www.RUNRAPTORRUN.com
The Macf
Vegas
Nice. I've been thinking about painting mine white.
McDowell
Oklahoma
Yukon Joe
Billet. I saw someone on here not long back who had installed one and it looked good but can't find it again
svt_ivan
Dallas, TX
Don't know if you're talking about these, but if so it was me who posted the photozuty4uhu.jpg
McDowell
Oklahoma
Yes those are nice! Where did you get them. I guess they aren't mirror reflector replacements but close enough
