Gen1TillDeath
cincinnati
Do you think you will reuse the stock trans line fittings given their getting to be prone to breaking? I saw “Fordtechmakuloco “ video he did recently about them and it’s made me want get some “T bolt clamps” and snip the stock ends off.
TomDirt
Hesperia CA
When I looked at the fittings it occurred to me that if anything broke offroad (and you stopped in time), a sharp knife, hose clamps, and some tubing would fix it. So that will be included in the gear box.
jackjare9455
Longview, TX
I remember I was flying in a Seahawk and we started getting some pot shots and I asked where they were coming from... the other guy in the bird replied "probably from below us"
******* thanks bro.
I was in a c-130 from Kuwait, into Iraq. All of the sudden the plane starts making maneuvers like the pilot is having a seizure… then the sky lights up from counter measures… ******* has never been the same from that pucker… nothing like riding on a floating roller coaster with zero control of your death
jackjare9455
Longview, TX
Lower radiator hose is off. Tough job... the access was tight. I had to remove the exhaust manifold heat shield (2) 5/16" bolts before I could get a vise grip on the hose clamp on the motor side of the hose. Good Times!View attachment 396151
I thought about replacing this hose with my coolant drain… I guess I’ll think harder now lol
laselvasurf
Santa Cruz, CA
I added a 12V connector in the wheel well to power a tire inflator. I got tired of people stopping and asking if I was okay with my hood open so I could attach the Viair directly to the battery. I was concerned it would get dirty/dusty, but I tested it out in one of the muddiest areas I've been yesterday and that area stayed plenty clean.
Also did a couple hours of off-roading yesterday with the truck loaded down with around 1000lbs in the bed and 5 adults in the cab. It was the first heavier trip I've done since installing the rear bump stops and they definitely put in some work. I still need to fine tune the PSI(if anyone has any recommendations, on that let me know!).
View attachment PXL_20230304_174837767_1.mp4
