Yukon Joe
Trafford, PA
@AdamsPolishes
Finally got the SnoBall of my truck.
And had a chance to get that cool sticker put in the window.
The foam canon was a blast to use (pun intended).
Only question, how do you get all those suds to stay on the truck? Mine kept running off....
Yukon Joe :baby: :baby:
Delta Lead
www.runraptorrun.com
---------- Post added at 08:59 PM ---------- Previous post was at 08:51 PM ----------
I love that detail spray on the wrap. Makes it look so vibrant!
Also used the waterless wash before the soap today. It really did a good job of loosening the big guts and other marks on the wrap.
Thanks for the tip.
Delta Lead
Zeke555
Sherwood Park, Alberta, Canada
Finished building and mounting bed rail mounts that @602 Raptor designed. Next step is to make "mesh panelling" or something similar to run between the front and rear mounts so I can mount molle pouches, fuel hose holder for Sceptre fuel cans, etc. Tomorrow or Tuesday need to wash the truck. We had a warm spell and I found a couple big puddle that I had to go blasting through. If it is going to be dirty, might as well make it good and dirty everywhere!! ;)
AdamsPolishes
@AdamsPolishes
Delta Lead
Thanks for the tip.
Delta Lead
Night Raptor is clean again! New sticker looks good too!
Glad the Waterless Wash helped. The suds do run off fairly quick. Try spraying the suds with the foam gun in a couple rounds, so you have time to wash before they run off. I spray the top third (windows and up) and then wash these areas. Then spray suds on the middle third and wash, then spray suds on the lower third (rockers and bumpers) and wash.
Wait to rinse the truck until it is completely washed, since the Car Wash Shampoo will prevent water spots, even if it dries.
You might try the Super VRT on the vinyl after drying with the Detail Spray. The SVRT will help hide some of the pinstripes, and also adds a lot of UV protection to keep the vinyl from fading and from drying out.
-Dan
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Those hose attachments simply don't put out the same density and volume of foam as a lance attached to a pressure washer which sticks like shaving cream. They still do the trick though.
