Welder recommendations
Glo
if you want to go low cost and 110/220 AHP 200X
Deletedone
Deletedone
nunya, ca
Thanks for the input guys, I ended up ordering this: http://www.millerwelds.com/products/mig/product.php?model=M00245 Mainly because it was in my price range, does 110V or 220V and can weld up to 3/8" steel which I think is probably the upper limit of what I would ever be building, if I'm welding something heavier gauge than that I would want it done professionally. Let me know what you guys think, as I have until Monday to change my mind.
Darthyota
Alberta Canada
nice pick. if i remember correctly thats 3/8's in a single pass so it can weld thicker just need to do more then one pass and make sure you've got the proper joint design
Hole Shot
Raeford, Nc.
Since we have some professional a welders in here and I am not. I was gonna try and stick weld a mercruser block that I have that is cracked. It is still in the boat. I was gonna remove it and attempt to weld the two cracks in the water jackets with some nickel rod. I have seen a couple shows/articles about this. Anyone have any experience welding a cast block?
Hole Shot
Raeford, Nc.
Right!! I have also seen where people have peened the weld to help relieve the stress of cooling. What do you guys think would be easier a eng. block or reinforcing some spindle carriers. I gotta practice on something.
Sorry for the hijack!!!
Brando
NW New Jersey
Miller 211...I like the option of 110 or 220. I use on farm equipment all the way to welding a canoe.
Sent from my SM-N900V using Tapatalk
