Hey J, how'd you wire it all up? I just got the same system, minus the tank, and was gonna probably do it this weekend. Do you have it hard wired to the battery and did you use one of the upfitter switches?
Heya 'Mech.
No its not hard wired to the battery and yes I used one of the upfitter switches. I was able to just use the upfitter switch, and therefore the Ford OEM relay and Ford OEM fuse; no need to wire anything to the battery since the upfitter system handles all that for us.
The 10007 kit comes with a relay/pressure switch combo unit for use with the tank, and a fuse inline between that relay/switch and the battery. I opted not to use their relay/pressure switch and fuse, and instead I used a simple pressure switch only. I wired the hot of that switch to upfitter 2. Simple and clean, and best of all it keeps all my relays and fuses Ford OEM, and in one central spot.
I would assume you didn't get that relay/switch combo, and that yours came with a separate relay, separate pressure switch and separate fuse? If so, your install should be just as easy as mine was. Set aside the relay pressure switch and fuse, and instead just wire the hot from the compressor to upfitter 1 or 2. Keep in mind the system will demand 19amp peak, so you'll want to use switch one or two only.
You probably have this, but just in case, it should help you figure things out:
![aux_wiring3.png aux_wiring3.png](https://www.fordraptorforum.com/data/attachments/170/170015-fc37098d8a71313ecf2fe67bc79780e5.jpg)
