Ryan from VIAIR
Hi guys, I just stumbled across this thread...I know this thread is a few months old so this post might be in vain but I I want to help by addressing these issues anyways.
Big J - Thanks for documenting all of this. It helps educate potential customers about what to do and what not to do when installing.
My goal is to offer tech support so I read through the 12 pages and here's what I can contribute.
1. All of our compressors come with a check valve. This particular model has a check valve built in to the tip of the leader hose. Installing this check valve is tricky because most people use a wrench to tighten it down, however that often results in over-tightening the check valve and collapsing the threads which are naturally tapered around the plunger and spring inside the check valve. So to prevent this from happening, you should use Loc-tite 545 and then hand tighten the check valve. If you use a wrench, use no more than 10-12lbs of torque. Then a few hours to let the loc-tite set in.
2. The original install had the leader hose bent right at the head of the compressor straight down. This could definitely create some heat problems and result in a leak within the leader hose. The leader hose should be be bent more than 180 degress and the angle needs to be as obtuse as possible. Remember: This is 200PSI and we use a steel braided leader hose because the temperatures get up to 200 degree F. You wouldn't kink your garden hose like that, so you definitely don't want to kink your leader hose.
3. The new install had 90 degree fitting and the pressure switch was plumbed within 6 inches from the head of the compressor. The heat transfer coming off the head of the compressor may damage the pressure switch. It is better to plumb the pressure switch to the air tank as opposed to near the cylinder head. Also, moisture is a by product of compressed air so the pressure switch should not be oriented on the underside of any fittings because if moisture settles it will fall into the pressure switch.
4. The compressor should never be able to run unless the engine is running because the pressure switch should only be activated by the accessory ignition. If your compressor turns on by itself even while the engine is off, then that means the pressure switch is connected directly to the car battery which does not guarantee that your compressor is receiving 13.8 volts, should a leak occur. If the compressor is turned on without the engine running, this will result in a volt drop/amp spike, thus giving you a possible reason as to why your fuse is blowing. There are other reasons that a fuse might be blowing such as, too small of a wire, a bad check valve, a broken reed valve, or a bad ground.
Here's the wiring diagram that we include.
http://www.viaircorp.com/OffRoad/Schematics/oba_wd.pdf
Please feel free to e-mail me at
ryans@viaircorp.com or call 949 585 0011 if you have any other tech questions.
I will try to keep my eye on this forum as well.
