Aksubiedubie
Hand formed intercooler end tanks out of 0.0625" ... 5083 aluminum? I forget.
It held plenty of pressure in the STI with the 750hp garrett core that I built. Ran 33psi of boost on that out of an EFR 8374 (79lb/min or ~790hp)
4 inch outlet. Trimmed it a bit after. I wanted minimum volume while keeping efficient flow (based on eyeballing a ton of optimized intercooler end tanks from formula 1, and other CFD simulation images on the internet)
Spent some time with a die grinder after welding to smooth the outlet towards a mini velocity stack type config.
Finished product with 2 3" inlets and 1 4" outlet:
After the intercooler I pre-fabbed the Y pipe for underneith using solar flux. Worked pretty good. Feels nice not using a ton of argon... shit is expensive nowadays.
Here is the final config and some of the last pictures I took since a week or two ago.
Got some matte black/reflective blue graphics from josh @ rappygraphics
---------- Post added at 09:42 PM ---------- Previous post was at 09:40 PM ----------
Ha thanks. It's been kind of a *********** but I'm really happy I got the hardest part done. The downpipes and Y pipe will be easy since I got a pipe expander and can just do short slip fits with solar flux.
You sir are an inspiration. Keep up the good work. I hope it goes smoothly!
Sent from my VS987 using Tapatalk
