As mentioned earlier; Magnuson moss only applies to OEM equivalent parts. So if you bring your vehicle to the dealer for SYNC update, they can't void your engine warranty because you have a Mobil 1 oil filter and not a Motorcraft. The exception to that is when the aftermarket part is directly attributed to the failure. For example, a Fram oil filter coming apart and the filter media being sucked through the oil pump.
In the case of this transmission issue, its all dependent on what the dealer finds upon teardown and inspection. The failure will be electrical related (pinched/chafed wire, faulty shift solenoid, faulty speed sensor, etc.) or mechanical related (sticking clutch control valve, leaking clutch piston, cracked transmission fluid filter housing, etc.). In the event that they find no electrical concerns or control component concerns and damage is present such as burnt clutches/steels, damaged planetary gear teeth, or a cracked planetary carrier, this will most likely be attributed to the additional load on the transmission from the tune.
Note that it is also possible that the TCM may have the following DTC stored in memory, which is an indication of an aftermarket calibration being installed at some point (but not necessarily present at this time).
P064F:00 Unauthorized Software/Calibration Detected: No Sub Type Information
Please let us know what they find.
